Saltar al contenido principal
1999-2002 Suzuki SV650 Seat Replacement
Qué necesitas
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: paso 1, imagen 1 de 2 1999-2002 Suzuki SV650 Seat Replacement, Seat: paso 1, imagen 2 de 2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
Conclusión
Una persona más ha completado esta guía.
Phillip Takahashi
Miembro Desde 08/22/11
86,704 Reputación
87 Guías creadas
Un comentario
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 54
Todo El Tiempo: 7,883
