Saltar al contenido principal
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
Qué necesitas
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: paso 1, imagen 1 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: paso 1, imagen 2 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: paso 1, imagen 3 de 3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: paso 2, imagen 1 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: paso 2, imagen 2 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: paso 2, imagen 3 de 3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: paso 3, imagen 1 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: paso 3, imagen 2 de 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: paso 3, imagen 3 de 3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
Conclusión
To reassemble your Jeep, follow these instructions in reverse order.
8 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
784,298 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
560 Guías creadas
4 comentarios
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - Contestar
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - Contestar
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 55
Todo El Tiempo: 9,922
