Saltar al contenido principal
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
Qué necesitas
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: paso 1, imagen 1 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: paso 1, imagen 2 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: paso 1, imagen 3 de 3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: paso 2, imagen 1 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: paso 2, imagen 2 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: paso 2, imagen 3 de 3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
Conclusión
6 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
789,677 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
34 Miembros
597 Guías creadas
4 comentarios
It’s a 7mm socket
Don Marcos - Contestar
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Contestar
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 34
Todo El Tiempo: 7,647
