Saltar al contenido principal
1999-2011 Ford Ranger Tail Light Bulb Replacement
Qué necesitas
  1. 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 3 de 3
    • Pull the tailgate latch and lower the tailgate down so that it is open.
  2. 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 2, imagen 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 2, imagen 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 2, imagen 3 de 3
    • Remove the two 19mm Phillips #1 screws on the taillight housing that face the inside of the bed.
    • Remove the two 38mm Phillips #1 screws on the taillight housing that face the outside of the truck.
  3. 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 3, imagen 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 3, imagen 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 3, imagen 3 de 3
    • Pull the taillight housing down from the truck so that the wires and plugs are exposed.
  4. 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 4, imagen 1 de 1
    • Remove any dirt or dust around the taillight plug so that nothing falls into the lens.
  5. 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 5, imagen 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 5, imagen 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 5, imagen 3 de 3
    • Loosen and remove the taillight plug so that the bulb is exposed.
  6. 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 6, imagen 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 6, imagen 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: paso 6, imagen 3 de 3
    • Remove the old or damaged bulb.
    • Insert the new bulb into the exposed plug and then insert the plug back into the taillight housing and tighten.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 105
Todo El Tiempo: 6,981
