Saltar al contenido principal
1997 Saturn II Passenger Side Mirror Replacement
Qué necesitas
  1. 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: paso 1, imagen 1 de 3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: paso 1, imagen 2 de 3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: paso 1, imagen 3 de 3
    • Pry the plastic panel away from the base of the side mirror with a metal spudger or your hands.
  2. 1997 Saturn II Passenger Side Mirror Replacement: paso 2, imagen 1 de 3 1997 Saturn II Passenger Side Mirror Replacement: paso 2, imagen 2 de 3 1997 Saturn II Passenger Side Mirror Replacement: paso 2, imagen 3 de 3
    • Remove the three 10 mm bolts using the 10 mm socket and ratchet extension.
    • If there is an existing side mirror attached, hold it to keep it from falling.
  3. 1997 Saturn II Passenger Side Mirror Replacement: paso 3, imagen 1 de 1
    • Remove the existing side mirror if there is one attached.
  4. 1997 Saturn II Passenger Side Mirror Replacement: paso 4, imagen 1 de 1
    • Mount the replacement passenger side mirror.
    • Ensure it lays flat with the car.
  5. 1997 Saturn II Passenger Side Mirror Replacement: paso 5, imagen 1 de 3 1997 Saturn II Passenger Side Mirror Replacement: paso 5, imagen 2 de 3 1997 Saturn II Passenger Side Mirror Replacement: paso 5, imagen 3 de 3
    • Hold the side mirror in the slot.
    • Tighten one 10 mm bolt as much as you can by hand first to keep the mirror in place, and then tighten the remaining two 10 mm bolts.
  6. 1997 Saturn II Passenger Side Mirror Replacement: paso 6, imagen 1 de 2 1997 Saturn II Passenger Side Mirror Replacement: paso 6, imagen 2 de 2
    • Replace the plastic panel by snapping it back on.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 415
