Saltar al contenido principal
1997-2003 Chevrolet Malibu Air Filter Replacement
Qué necesitas
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: paso 1, imagen 1 de 2 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: paso 1, imagen 2 de 2
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: paso 2, imagen 1 de 2 1997-2003 Chevrolet Malibu Air Filter Replacement: paso 2, imagen 2 de 2
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: paso 3, imagen 1 de 1
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: paso 4, imagen 1 de 1
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
Conclusión
4 personas más completaron esta guía.
Sank Yang
Miembro Desde 10/03/12
484 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-15, Amido Fall 2012 Miembro de Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 40
Todo El Tiempo: 5,517
