Partes
No se requieren partes.
Resumen del Video
A video about installing MP3 Player in BMW E39 http://www.youtube.com/watch?v=_6wg3qTvU....
  1. Remove screws holding the CD changer in place (if equipped)
    • Remove screws holding the CD changer in place (if equipped)
    • Disconnect BMW CD changer 3 pin power plug and 6 pin audio plug from CD changer.
    • Connect MP3 Player to original CD changer connectors
  2. If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
    • If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
    • A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system
    • Switched power is located on pin 24 Violet/White (or Violet/Red see image.
    • If you are also installing the DSP adapter module with your MP3 player you can connect the DSP module adapter to this pin in addition to using pin 14 brown/black for ground.
Conclusión
3 personas más completaron esta guía.
Martin Bishop
Miembro Desde 26/01/12
3,926 Reputación
16 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 36
Todo El Tiempo: 11,505
