Saltar al contenido principal
1997-2006 Jeep Wrangler (TJ) Headlight Replacement
Qué necesitas
  1. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement, Headlight: paso 1, imagen 1 de 1
    • Unclasp and prop up the hood.
  2. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 2, imagen 1 de 1
    • Remove the three 15.9 mm screws around the external ring casing with a Phillips #0 screwdriver.
  3. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 3, imagen 1 de 1
    • Pull out the external ring casing.
  4. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 4, imagen 1 de 2 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 4, imagen 2 de 2
    • Remove the four screws securing the internal ring casing with a T15 Torx screwdriver.
  5. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 5, imagen 1 de 1
    • Disconnect the headlight assembly from the vehicle by pulling the connector directly out of the back port.
  6. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 6, imagen 1 de 1
    • Realign the internal bracket to match the screw holes.
  7. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 7, imagen 1 de 1
    • Reinstall the four screws securing the internal ring casing with a T15 Torx screwdriver.
  8. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 8, imagen 1 de 1
    • Realign the external bracket to match the screw holes.
  9. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 9, imagen 1 de 1
    • Replace the three 15.9 mm screws using a Phillips #0 screwdriver.
  10. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: paso 10, imagen 1 de 1
    • Close and clasp the hood back to its original position.
Conclusión
Enjoy your bright new headlight(s)!
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 74
Todo El Tiempo: 3,444
