Introducción
If your radio has stopped working or you are looking to upgrade your factory radio, you can use this guide to remove the factory radio from your 1995-2001 Honda CRV. Follow these steps to remove the radio.
Qué necesitas
Remove the clips in the glovebox by pushing them in.
Using a Phillips #0 screwdriver, remove one screw on left side of the glovebox frame and one screw on the right side of the glove box.
8 personas más completaron esta guía.
3 comentarios
I had a single DIN ALPINE stereo “professionally” installed in my late dad’s 2001 CRV. Two weeks after the install, it starts to rattle, had a broken aftermarket single DIN radio already installed, NEVER rattled! Now, I just discovered that if I put my hand in the tray under the new radio, the whole console piece with the radio and HVAC knobs just slides out! Did they forget the 13mm side screws that hold it in??? Or, damaged something else back there? Very upset!!! Any ideas??
After the removal you may need Honda radio code that will help you unlock your original radio (if you decide to use it). I had the same problem before a month. I solve it using the guide from this unlock Honda page: https://www.hondaradiocodebyvin.com/!
Following the removal, you might require the Honda radio code to facilitate unlocking your original radio should you choose to reinstall it. I encountered a similar issue a month ago and successfully resolved it by referring to the instructions provided on this Honda unlocking page: CAR RADIO CODE UNLOCK SERVICE
