Saltar al contenido principal
1995-2001 Honda CRV Radio Replacement
Qué necesitas
  1. 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: paso 1, imagen 1 de 3 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: paso 1, imagen 2 de 3 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: paso 1, imagen 3 de 3
    • Remove the clips in the glovebox by pushing them in.
    • Using a Phillips #0 screwdriver, remove one screw on left side of the glovebox frame and one screw on the right side of the glove box.
  2. 1995-2001 Honda CRV Radio Replacement: paso 2, imagen 1 de 3 1995-2001 Honda CRV Radio Replacement: paso 2, imagen 2 de 3 1995-2001 Honda CRV Radio Replacement: paso 2, imagen 3 de 3
    • Use your hands to open the fold-down pocket.
    • Use a Philips #0 screwdriver to remove the four screws surrounding the fold-down pocket.
    • Use the Phillips #0 to remove the final screw from the fold-down pocket.
  3. 1995-2001 Honda CRV Radio Replacement: paso 3, imagen 1 de 2 1995-2001 Honda CRV Radio Replacement: paso 3, imagen 2 de 2
    • Use a plastic panel tool to remove the plastic clip from the left side of the trim panel below the fold down pocket.
    • Use the same panel tool to remove the plastic clip from the right side of the trim panel below the fold down pocket.
  4. 1995-2001 Honda CRV Radio Replacement: paso 4, imagen 1 de 2 1995-2001 Honda CRV Radio Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two screws from the driver-side dashboard.
    • Use a plastic panel tool to unclip the edges of the dashboard.
  5. 1995-2001 Honda CRV Radio Replacement: paso 5, imagen 1 de 2 1995-2001 Honda CRV Radio Replacement: paso 5, imagen 2 de 2
    • Use your hands to pull off the center dash.
    • Remove the 13mm screws connecting the console to the frame.
  6. 1995-2001 Honda CRV Radio Replacement: paso 6, imagen 1 de 1
    • Use your hand to unplug the cigarette lighter and A/C Controls.
    • Use caution to avoid damaging the wires.
  7. 1995-2001 Honda CRV Radio Replacement: paso 7, imagen 1 de 2 1995-2001 Honda CRV Radio Replacement: paso 7, imagen 2 de 2
    • Use your hands to gently remove the radio bezel.
    • Use your fingers to unclip the radio harness from the radio.
Conclusión
8 personas más completaron esta guía.
Adam Huth
Miembro Desde 01/17/17
290 Reputación
1 Guía escrita
Equipo
3 comentarios
I had a single DIN ALPINE stereo “professionally” installed in my late dad’s 2001 CRV. Two weeks after the install, it starts to rattle, had a broken aftermarket single DIN radio already installed, NEVER rattled! Now, I just discovered that if I put my hand in the tray under the new radio, the whole console piece with the radio and HVAC knobs just slides out! Did they forget the 13mm side screws that hold it in??? Or, damaged something else back there? Very upset!!! Any ideas??
savroof - Contestar
After the removal you may need Honda radio code that will help you unlock your original radio (if you decide to use it). I had the same problem before a month. I solve it using the guide from this unlock Honda page: https://www.hondaradiocodebyvin.com/!
angelovblaze - Contestar
Following the removal, you might require the Honda radio code to facilitate unlocking your original radio should you choose to reinstall it. I encountered a similar issue a month ago and successfully resolved it by referring to the instructions provided on this Honda unlocking page: CAR RADIO CODE UNLOCK SERVICE
gregory - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 146
Todo El Tiempo: 25,773
