Saltar al contenido principal
1994-2001 Acura Integra Front Speaker Replacement
Qué necesitas
  1. 1994-2001 Acura Integra Front Speaker Replacement, Door Panel: paso 1, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement, Door Panel: paso 1, imagen 2 de 2
    • Remove the plastic Phillips screw towards the front of the door panel.
    • This screw is part of a two-piece securing mechanism. Do not apply force directly onto the screw head, because it will continue to slip into the plastic clip.
    • Use a flathead screwdriver to remove the plastic clip that holds the screw.
  2. 1994-2001 Acura Integra Front Speaker Replacement: paso 2, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement: paso 2, imagen 2 de 2
    • Unscrew the Phillips screw in the bottom of the door panel cup.
    • Lift the cup out of the the door panel.
  3. 1994-2001 Acura Integra Front Speaker Replacement: paso 3, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement: paso 3, imagen 2 de 2
    • Insert a very thin flathead screwdriver blade into the small gap towards the rear of the car on the plastic screw cover near the door handle.
    • Unscrew the Phillips screw underneath the screw cover.
  4. 1994-2001 Acura Integra Front Speaker Replacement: paso 4, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the plastic cover at the base of the C-pillar by pulling it directly away from the window.
    • The cover is held in place by a metal clip, so some force will be required to free it.
    • In addition to the metal clip, two small tabs at the bottom of the cover keep it in place. Gently lift the corner of the door panel to remove the tabs from their respective holes in the door.
  5. 1994-2001 Acura Integra Front Speaker Replacement: paso 5, imagen 1 de 3 1994-2001 Acura Integra Front Speaker Replacement: paso 5, imagen 2 de 3 1994-2001 Acura Integra Front Speaker Replacement: paso 5, imagen 3 de 3
    • Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side.
    • Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
  6. 1994-2001 Acura Integra Front Speaker Replacement: paso 6, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement: paso 6, imagen 2 de 2
    • Pull the bottom of the door panel away from the door, and lift the entire panel off the door.
    • Do not try to completely remove the door panel yet, as it is still attached by a number of electrical connectors.
  7. 1994-2001 Acura Integra Front Speaker Replacement: paso 7, imagen 1 de 3 1994-2001 Acura Integra Front Speaker Replacement: paso 7, imagen 2 de 3 1994-2001 Acura Integra Front Speaker Replacement: paso 7, imagen 3 de 3
    • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
    • Use the same method described above to remove the connector for the tweeter.
    • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  8. 1994-2001 Acura Integra Front Speaker Replacement: paso 8, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement: paso 8, imagen 2 de 2
    • Disconnect the power window connector.
    • You may now remove the entire door panel.
  9. 1994-2001 Acura Integra Front Speaker Replacement, Front Speaker: paso 9, imagen 1 de 2 1994-2001 Acura Integra Front Speaker Replacement, Front Speaker: paso 9, imagen 2 de 2
    • Remove the four Phillips screws that hold the speaker in the door.
    • Lift the speaker out of the door. It is still connected by a single connector.
    • Press down on the tabs on the speaker connector, and pull it directly away from the speaker.
Conclusión
3 personas más completaron esta guía.
David Hodson
Miembro Desde 04/13/10
149,182 Reputación
127 Guías creadas
Un comentario
On my 2000 Integra GS 2-door model, this was much easier than described here. I didn't have to take off the door panel at all. I just popped the speaker grille off with a flat-head screwdriver, and the speaker was accessible from there.
To remove the speaker grille, pry from the bottom side with a flat instrument and the bottom edge will pop out. The top edge has tabs that have to slide down for grille removal.
My front speakers (6.5" size) had 3 screws mounting them in. All 3 screws were accessible after removing the speaker grille. To remove the speaker, take those screws out, then tilt it forward so that the top edge leans out first. Then you can lift it up and out far enough to reach the wire plug and press the plug release clips with your thumb and forefinger to unplug it.
Not much else to the job of speaker removal, for the front ones. The back ones are more difficult though - you must remove the rear side panel to get those out. But it's definitely worth it to replace those dull-sounding factory speakers with some aftermarket ones!
Tobe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 23,827
