Saltar al contenido principal
1992-1999 BMW 3 Series Front Seats Replacement
Qué necesitas
  1. 1992-1999 BMW 3 Series Front Seats Replacement, Front Seats: paso 1, imagen 1 de 3 1992-1999 BMW 3 Series Front Seats Replacement, Front Seats: paso 1, imagen 2 de 3 1992-1999 BMW 3 Series Front Seats Replacement, Front Seats: paso 1, imagen 3 de 3
    • Loosen the 13mm nuts on each battery terminal.
    • Remove both the positive and negative terminals.
  2. 1992-1999 BMW 3 Series Front Seats Replacement: paso 2, imagen 1 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 2, imagen 2 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 2, imagen 3 de 3
    • Remove the two 15mm nuts in the front and two 15mm bolts in the rear of the driver's seat.
  3. 1992-1999 BMW 3 Series Front Seats Replacement: paso 3, imagen 1 de 2 1992-1999 BMW 3 Series Front Seats Replacement: paso 3, imagen 2 de 2
    • Remove the two wire connections underneath the rear of the driver's seat.
  4. 1992-1999 BMW 3 Series Front Seats Replacement: paso 4, imagen 1 de 2 1992-1999 BMW 3 Series Front Seats Replacement: paso 4, imagen 2 de 2
    • Remove the seat from the car and clean the area of debris.
    • This is where the rails for the seat sit so ensure there is no debris or floor mats in this area before reinstalling the seats.
  5. 1992-1999 BMW 3 Series Front Seats Replacement: paso 5, imagen 1 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 5, imagen 2 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 5, imagen 3 de 3
    • Reinstall the driver's seat, and line up the studs in the front with the front holes of the seat rails. Loosely reinstall the two front nuts and the two rear bolts.
    • Tighten all of the hardware.
    • Reconnect the two electrical connectors under the rear of the seat.
  6. 1992-1999 BMW 3 Series Front Seats Replacement: paso 6, imagen 1 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 6, imagen 2 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 6, imagen 3 de 3
    • Remove the two 15mm nuts in the front and two 15mm bolts in the rear on the passenger seat.
  7. 1992-1999 BMW 3 Series Front Seats Replacement: paso 7, imagen 1 de 1
    • Remove the three wire connections underneath the rear of the passenger seat.
  8. 1992-1999 BMW 3 Series Front Seats Replacement: paso 8, imagen 1 de 2 1992-1999 BMW 3 Series Front Seats Replacement: paso 8, imagen 2 de 2
    • Remove the passenger seat from the car and clean the area of debris.
  9. 1992-1999 BMW 3 Series Front Seats Replacement: paso 9, imagen 1 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 9, imagen 2 de 3 1992-1999 BMW 3 Series Front Seats Replacement: paso 9, imagen 3 de 3
    • Reinstall the passenger seat, and line up the studs in the front with the front holes of the seat rails. Loosely reinstall the two front nuts and the two rear bolts.
    • Reconnect the three electrical connectors under the rear of the seat.
  10. 1992-1999 BMW 3 Series Front Seats Replacement: paso 10, imagen 1 de 1
    • Reconnect and tighten down the 13mm nuts on the battery terminals in the trunk.
Conclusión
Enjoy your new or refreshed seat
Kai Michael David Enright
Miembro Desde 02/20/24
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 105
Todo El Tiempo: 156
