Saltar al contenido principal
1991-1996 Toyota Camry Headlight Replacement
Qué necesitas
    • To lift the hood of the car, pull the latch with the “hood up” icon up towards you. This latch can be found below the steering wheel and sits directly above where your left foot rests.
    • After lifting the hood of the car, click the latch (located just above the Toyota logo visible on the front bumper) holding the hood down upward. Lift the hood upward.
    • Locate the headlight bulb plug (right side headlight plug shown). This can be found underneath the hood and is positioned directly behind the headlight.
    • Once you’ve found the headlight bulb plug (left side shown), twist the plug out of its locked position by rotating it counter clockwise (as seen in the video).
    • Pull the plug toward you to completely remove it.
    • On the backside of the bulb socket, click the release lever down (as seen in the video). This will allow you to remove and replace the bulb
    • Pull the old bulb end (which rests just above the previously mentioned release level) up to remove it
    • Push new bulb end down until it clicks into position
    • Do not touch the glass of the new bulb with your hands during installation. Oils from your fingers can overheat the glass and cause premature failure .
Conclusión
7 personas más completaron esta guía.
Matt Bowman
Miembro Desde 10/24/15
167 Reputación
1 Guía escrita
Equipo
PIRL Gadget Garage Miembro de PIRL Gadget Garage
Community
9 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 6,698
