Saltar al contenido principal
1990-1993 Honda Accord EX Engine Air Filter Replacement
Qué necesitas
  1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 2 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 3 de 3
    • Flip the switch underneath the steering wheel to open the hood.
  2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 2, imagen 1 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 2, imagen 2 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 2, imagen 3 de 3
    • Open the hood, and keep it in place using the prop rod.
  3. 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 3, imagen 1 de 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 3, imagen 2 de 2
    • Remove the four 1.3 cm Phillips screws from the cover of the case.
  4. 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 4, imagen 1 de 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 4, imagen 2 de 2
    • Remove the cover of the casing.
  5. 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 5, imagen 1 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 5, imagen 2 de 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 5, imagen 3 de 3
    • Remove the old air filter and replace it with a brand-new one.
    • Place the new air filter in the same position as the old one otherwise, you will not be able to screw the cover back on.
  6. 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 6, imagen 1 de 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: paso 6, imagen 2 de 2
    • Place the cover back on the casing and screw it back in place.
    • Do not tighten the screws too hard or you risk the chance of breaking the screws.
Conclusión
Oscar Sanchez
Miembro Desde 10/24/23
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 102
