Introducción
Replacing your Volvo's engine air filter is one of the easiest things you can do to keep your engine healthy and breathing right. Check your engine air filter at every oil change and replace it when it is dirty, usually around every 12,000 miles.
Herramientas
No se requieren herramientas.
Partes
  1. The engine air filter housing is located at the front of the engine bay, between the engine and the radiator.
    • The engine air filter housing is located at the front of the engine bay, between the engine and the radiator.
    • Open the lid of the filter housing by releasing the metal clips along the edge of the lid.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Once the clips are released, pull the lid away from the air filter housing. Grab the air filter and remove it from the filter housing.
    • Once the clips are released, pull the lid away from the air filter housing.
    • Grab the air filter and remove it from the filter housing.
    • Be sure to install the new air filter in the same orientation as the old one.
Conclusión
Una persona más ha completado esta guía.
David Hodson
Miembro Desde 13/04/10
133,454 Reputación
127 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 8
Últimos 30 Días: 51
Todo El Tiempo: 5,526
