Saltar al contenido principal
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
Qué necesitas
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: paso 1, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: paso 1, imagen 2 de 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 2, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 2, imagen 2 de 2
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 3, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 3, imagen 2 de 2
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 4, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 4, imagen 2 de 2
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 5, imagen 1 de 1
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 6, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 6, imagen 2 de 2
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 7, imagen 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 7, imagen 2 de 2
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 8, imagen 1 de 3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 8, imagen 2 de 3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 8, imagen 3 de 3
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: paso 9, imagen 1 de 1
    • Reattach the electronic cable to the MAF.
Conclusión
Isaac Nitschke
Miembro Desde 10/11/10
67 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-28, Regan Fall 2010 Miembro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 27
Todo El Tiempo: 9,646
