Firstly Disconnect  battery
  • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Agregar Comentario
Unlatch the 2 clasps.
  • Unlatch the 2 clasps.
  • Loosen screw on metal band.
Agregar Comentario
  • Disconnect electronic sensor.
  • Press on the 2 latches, pulling the cable away from sensor.
Agregar Comentario
  • Disconnect hose from MAFS.
  • Remove MAFS.
Agregar Comentario
  • Steps 4-6 are for cleaning only.
  • Spray MAFS cleaner along direction of travel, shown by arrow.
Agregar Comentario
  • Clean electronic coupling with electronics cleaner.
Agregar Comentario
  • Inject conducting lubricant into MAFS electronic coupling.
Agregar Comentario
  • Re attach MAFS to air filter housing and intake hose.
  • Tighten screw on metal band.
  • Latch clasps on either side of MAFS.
Agregar Comentario
  • Re attach electronic cable to MAFS.
Agregar Comentario
Conclusión
Isaac Nitschke
Miembro Desde 11/10/10
61 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-28, Regan Fall 2010 Miembro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 50
Todo El Tiempo: 7,897
