Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
In order to perform several of the repair guides for the Volvo 740, the front wheels of the car must be raised off the ground. This guide will show you how to do this using a hydraulic car jack and jack stands.
Herramientas
Partes
No se especificaron partes.
  1. Turn car off and remove keys from ignition.
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. Use hydraulic jack on frame of car to raise car.
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  4. Place jack stand on frame of car and remove jack.
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
Conclusión
Isaac Nitschke
Miembro Desde 11/10/10
67 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-28, Regan Fall 2010 Miembro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,081
