Introducción
Use this guide to remove, inspect, and replace the rear brake pads. This guide shows you how to remove the brake pads and install new OEM pads. Worn brake pads increase stopping distance and can cause unwanted noise.
Firstly Disconnect battery
Always take the negative terminal off first.
'''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Turn car off and remove keys from ignition.
Place car in park (automatic) or neutral (manual).
Engage parking brake.
Pry off the front hub caps by placing a small flathead screwdriver between hubcap and rim and pulling the screwdriver and hubcap away from tire.
Una persona más ha completado esta guía.
