Introducción
This is a guide on replacing the headlight lamp on a 1980 Honda Prelude.
The headlight helps you and other drivers see at night or during storms. A faulty headlight can cause issues with visibility and with police.
Before following this guide, make sure you replace the headlights in pairs because if one headlight goes out, the other headlight will go out too.
Be sure once you have replaced your headlights to properly throw the old headlights in the trash. Make sure you replace your headlights first before going on the road.
Qué necesitas
Turn off the car, pull the key out of the ignition, and turn off the cars lights.
In Conclusion, learning how to replace your headlight bulb for your 1980 Honda Prelude is important for your, and other driver's safety on the road.
