Saltar al contenido principal
1922 GE AOU Fan Power cord Replacement
Qué necesitas
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: paso 1, imagen 1 de 2 1922 GE AOU Fan Power cord Replacement, Power cord: paso 1, imagen 2 de 2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: paso 2, imagen 1 de 1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: paso 3, imagen 1 de 1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: paso 4, imagen 1 de 1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: paso 5, imagen 1 de 1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: paso 6, imagen 1 de 1
    • Remove the switch and set it aside, then pull the wire through the grommet.
Conclusión
Una persona más ha completado esta guía.
Elias Dorna
Miembro Desde 06/08/16
125 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-5, Rauch SU 2016 Miembro de Texas Tech, Team 3-5, Rauch SU 2016
TTU-RAUCH-SU16S3G5
2 Miembros
1 Guía escrita
Un comentario
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 2,765
