Saltar al contenido principal
12-String Takamine G Series Guitar String Replacement
Qué necesitas
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: paso 1, imagen 1 de 3 12-String Takamine G Series Guitar String Replacement, Guitar String: paso 1, imagen 2 de 3 12-String Takamine G Series Guitar String Replacement, Guitar String: paso 1, imagen 3 de 3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: paso 2, imagen 1 de 2 12-String Takamine G Series Guitar String Replacement: paso 2, imagen 2 de 2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: paso 3, imagen 1 de 2 12-String Takamine G Series Guitar String Replacement: paso 3, imagen 2 de 2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: paso 4, imagen 1 de 3 12-String Takamine G Series Guitar String Replacement: paso 4, imagen 2 de 3 12-String Takamine G Series Guitar String Replacement: paso 4, imagen 3 de 3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: paso 5, imagen 1 de 1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: paso 6, imagen 1 de 3 12-String Takamine G Series Guitar String Replacement: paso 6, imagen 2 de 3 12-String Takamine G Series Guitar String Replacement: paso 6, imagen 3 de 3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: paso 7, imagen 1 de 2 12-String Takamine G Series Guitar String Replacement: paso 7, imagen 2 de 2
    • Turn the tuning peg counterclockwise to tighten the string.
Conclusión
Rey Navarro
Miembro Desde 09/27/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 66
