Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
(AAA) Cleaning battery leakage (Maxxum 5000/7000)
Qué necesitas
    1. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Change note: paso 1, imagen 1 de 2 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Change note: paso 1, imagen 2 de 2
      Herramienta utilizada en este paso:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Pregunta a FixBot
      Agregar Comentario
    1. (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: paso 2, imagen 1 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: paso 2, imagen 2 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: paso 2, imagen 3 de 3
      • This is WHY you clean the corrosion - not polish it off. This cover was properly treated, but it still required a wire brush cleanup as well!!!
      • Severe terminal damage (wire brush needed)
      • Had to use sandpaper to fix
      Pregunta a FixBot
      Agregar Comentario
    2. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: paso 3, imagen 1 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: paso 3, imagen 2 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: paso 3, imagen 3 de 3
      • Unscrew the battery cover from the body. Remove the bad batteries.
      Pregunta a FixBot
      Agregar Comentario
    3. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: paso 4, imagen 1 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: paso 4, imagen 2 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: paso 4, imagen 3 de 3
      • To thoroughly clean the AAA cover, you must disassemble it. You will not be able to fully clean it assembled.
      • Stick a screwdriver or pry tool in the side with one pin. DO NOT pry on the side with 2; it can break the second pin.
      • LIft up on the clip and remove it. This can be safely cleaned in a vinegar bath.
      Pregunta a FixBot
      Agregar Comentario
    4. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: paso 5, imagen 1 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: paso 5, imagen 2 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: paso 5, imagen 3 de 3
      • This step will REDUCE the nickel-plating damage, not prevent it.
      • Before cleaning the corossion, use a chemical like denatured alcohol and a disposable toothbrush to clean some of the corrosion. Once this is done, rinse and dry the cover.
      Pregunta a FixBot
      Agregar Comentario
    5. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: paso 6, imagen 1 de 2 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: paso 6, imagen 2 de 2
      • If there is any stubborn alkaline on the screw plate, sand the affected tab down until you have a good connection and STOP. The tabs are VERY THIN.
      • With the battery holder disassembled, clean the clip by soaking it in vinegar.
      • If affected, clean the tabs on the screw cover with a toothbrush or Q-Tip.
      Pregunta a FixBot
      Agregar Comentario
    6. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: paso 7, imagen 1 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: paso 7, imagen 2 de 3 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: paso 7, imagen 3 de 3
      • Slide the side with 2 pins in FIRST, then let it rest.
      • Push down to lock the cover in place. Note: You may need to push the plastic on the screw plate back with a pry tool.
      • Put it in the closed position, and check if it opens correctly and accepts batteries.
      Pregunta a FixBot
      Agregar Comentario
    7. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Test the camera: paso 8, imagen 1 de 1
      • Install fresh batteries and take a few test shots.
      • If it works, shoot on with the old cover if desired and convert later :-).
      • If the camera is still dead, try a known good cover, or buy a used one with no existing corrosion, and re-assess the camera.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Nick
Miembro Desde 11/10/09
105,574 Reputación
72 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 334
6,015 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 49
Todo El Tiempo: 1,230
