Qué necesitas
If your phone already has a screen protector, proceed to the next step.
If not, just cut a piece of tape to size and stick it on the glass. This will help you remove the broken glass later.
Now you can move on to the next step, where the hair dryer will be used. I thought it would be safer to get the motherboard out.
If you want to get the motherboard too, you can follow theSamsung Galaxy S III Motherboard Replacement Instructions. All the details are there.
Using an infrared thermometer, heat the surface to 70-80oC. This will weaken the glue, but will not damage the electronics.
Hold the hair dryer at a distance of 7-8 centimeters from the phone (approximately as in the picture). After setting a weak hair dryer mode, heat the frame for three to five minutes, depending on the strength of your hair dryer.
Be careful! If you overheat the matrix, you can cause color distortion. If you notice the slightest color distortion, turn off the hair dryer immediately.
If you work with a hair dryer, it may take up to an hour.
Using a mediator or plastic spatula, start separating the edges of the glass very carefully.
Start from above, and continue moving down.
You will need a hair dryer several times while you separate the glass. If your glass is badly damaged, be very careful, otherwise you risk damaging the matrix with fragments.
At this step, you need to be very careful not to damage the buttons or cable! Using a spudger, separate the buttons from the inside of the glass. It may need to be warmed up a bit. Perhaps the best option is to start in the middle, under the middle cable connecting the two buttons, then separate each button.
7 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
