Introducción
READ ME: This guide has been archived by the author due to the age of this guide, and the fact this 360 is no longer around. I will not be updating this guide further. I have moved on from this guide but I feel like this could still help someone so I am keeping it around.
Game stuck in your Xbox 360? Here's a way that may work to remove it, in lieu of voiding the warranty (if the console is still under warranty).
Herramientas
Partes
No se requieren partes.
  1. Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
    Agregar Comentario
  2. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
  3. With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
    Agregar Comentario
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
    Agregar Comentario
Conclusión
17 personas más completaron esta guía.
Nick
Miembro Desde 10/11/09
43,739 Reputación
34 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
279 Miembros
758 Guías creadas
will this work for elite 250 gug
duangphetv - Contestar
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 30
Últimos 30 Días: 85
Todo El Tiempo: 29,225
