1 Respuesta 1 Puntaje |
La imagen se ve duplicada |
2 Respuestas 0 Puntaje |
Power button stuck in phone |
3 Respuestas 0 Puntaje |
Xiaomi Redmi Note - Led Blinking // Trying the Impossible... |
1 Respuesta 0 Puntaje |
The System Has Been Destroyed Problem |
Background and Identification
Developed by Chinese electronics manufacturer, Xiaomi Inc., the Xiaomi Redmi Note 5 is a smartphone and a part of Xiaomi’s budget friendly Redmi Note line. Released in February of 2018, the Note 5 is powered by a Snapdragon 625 processor.
The phone’s design is similar to its predecessor, the Redmi Note 4, especially when seen from the rear side. However, the Note 5 has a slimmer and lighter profile when compared to the Note 4. The back casing of the phone has an aluminum build while the top and bottom ends are plastic. At 180 grams, the phone is 8.1 mm thin and its weight gives the phone a sturdy feel. Also, users can find the fingerprint sensor on the rear panel. The front side of the Note 5 is the most different—with a minimal bezel display and no capacitive navigation buttons.
Technical Specifications
- Series: Xiaomi Redmi
- First released: February 2018
- Predecessor: Redmi Note 4
- Successor: Redmi Note 6 Pro
- Type: Touchscreen smartphone
- Form factor: Slate
- Dimensions
- Height: 158.6 mm (6.24 in)
- Weight: 75.4 mm (2.97 in)
- Depth: 8.1 mm (0.32 in)
- Maximum Depth: 9.2 mm (0.36 in)(camera)
- Mass: 181 g (6.4 oz)
- Operating system: MIUI 11 based on Android 9.0
- System on chip: Qualcomm SDM625
- CPU: Octa-core (8x A53 2.0 Ghz) Performance Kryo 260 cores based on Cortex A73 + 4x 1.6 GHz efficiency Kryo 260 cores based on Cortex A53)
- GPU: Adreno 506
- Memory: 3 or 4 GB RAM
- Storage: 32 GB or 64 GB
- Removable storage: microSDXC, expandable up to 256 GB (uses SIM 2 slot)
- Battery: Non-removable Li-Po 4000 mAh battery
- Display: 5.99 inches, 1080 x 2160 pixels, 18:9 ratio (403 ppi), IPS LCD capacitive touchscreen, 16M colors
- Rear camera: Dual: Samsung 12 MP (f/1.9, 1.25 μm) Dual-PD + Samsung 5 MP (f/2.0, 1.12 μm)
- Front camera: OmniVision OV13855 13 MP 1.0 μm
- Connectivity:
- 2G, 3G, 4G, 4G LTE
- Wi-Fi 802.11a/b/g/n/ac (2.4 & 5GHz), dual-band, WiFi Direct,
- hotspot Bluetooth V5,
- A2DP
- Low-energy
