Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 197 Ver todo
How do I remove the hard drive in the top bay?
I need to replace the hard drive located in the top bay at the rear of the enclosure. It just clicks and fails to spin up. the hard drive must slide out, and there is a tab that swings out of the way, but the case enclosure is in the way. Apple engineers are masters of making equipment accessible and repair friendly, but I am stumped on this one. There must be an easy way. Anyone know where the magic hard drive ejection lever button thingy is?
Thanks
Miccol
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Solución Elegida
You have to remove the bottom drive first. Throw down the locking tabs. remove the cables. Pul the bottom drive out, then the top drive. Watch how it comes out (top drive as it is a bit strange and you'll have to put it back in. Remove the four rubber screws on the sides to use in the next drive. Note there are four spares placed in the vertical partition wall.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thank you. New drive is in and ready to go. Writing zeros, Then new OS and apps.
I knew I was making it harder than it really is.
ifixit is a Godsend.
-Miccol
- de
Añadir tu respuesta
miccol estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,581
