Saltar al contenido principal
Encuentra soluciones a tus preguntas sobre reparación de ordenadores.
Preguntas 21172 Ver todo
Reinstalled Windows XP ,missing some drivers with the new install
Old hard drive failed,so I bought a new one.I had a copy of windows xp ,so I did a fresh install.But some of the drivers were not replaced after the fresh install.The following drivers are missing(Ethernet Controller)(Multimedia Audio Controller)(PCI simple communications controller)(RAID Controller)Does anyone know where I can find them to download?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hello Vernon!
Which computer do you have? You should be able to go to visit the company's website and download the drivers for you're computer model.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
This was rig made from the ground up for me.No real specific brand of PC.Is there someplace I can look in my system to see which manufacture to use?
- de
vernon, check for any marking or numbers on the motherboards. If you can not ID the motherboard from any distinct markings, I would suggest software like like thisIt will give you the details about your hardware. From those result, you should be able to get the drivers, either from the manufacturers website, or by doing a Google search. Hope this helps, good luck
Puntuación 1
3 comentarios:
I will look at the motherboard and see who the manufacture is.This is a great help,I'll let you know what I find out !
- de
Found the model number and went to the manufacturers web site and got the drivers!!!!!!!!!!Thanks for info it was spot on !!!
- de
Good Job, congratulations on getting it done:-)
- de
check out driverrobot.com if you ever are missing a driver it will find it and allow you to download them.
very good product for windows
Puntuación 0
Añadir tu respuesta
vernon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,014
