Screen hinges broken and only white screen
Both screen hinges are broken and some of the wire is displayed.
Help !
Es esta una buena pregunta?
Help !
Broken hinge
Alas, hinges on the Titanium series were not made out of titanium. This oversight by Apple means that broken hinges are an all-too-common problem on Titanium PowerBooks. Hinge repair is one of the few installations best left to professionals. Apple glued the display assembly tightly together, making opening the display without damaging the thin metal casing very difficult. For those who know exactly what they're getting into, we do offer hinges for sale. Please note that we do not have installation instructions available for these hinges.
A much easier installation is replacing the entire display assembly, which includes the hinges. We do offer complete LCD assemblies as well as installation instructions.PowerBook G4 Titanium DVI Display Replacement
Here's the part: [producto vinculado inexistente o deshabilitado: IF133-050]
Some pictures uploaded would certainly help ascertain the extent of your damage. Please look here to see if this is what you need: http://www.weloveMacs.com/clcopforg4ti.h...
Consider hooking up to an external monitor and external keyboard to make this a desktop machine.
Fue útil esta respuesta?
Video cable problem. Check the LVDS cable connection on the logic board. If it's not the problem buy a used but in good condition screen assy for the DVI Titanium on ebay. Opening the Titanium display is a nightmare (bezel glued and fragile) but you can do the repair (LVDS cable replacement ) if you're determined.
Thanks so much for your response:
Here's photos (little blurry,not a photographer). It fell less than 18" on a carpeted floor and here's the result.
Carolina, since you have screen lightning the inverter circuitry is still working but the cable that brings image to the screen must be damaged in the broken hinge or disconnected from the LCD panel or form the logic board. Does the computer boots ? Do your hear the chime when pushing on the power button ?
Thanks Lemerise.
I do hear the the chime and power up when I turn it on but the screen is white.
I connected it to an external monitor and I get the blue apple screen but that's all.
Could you boot from your installation disk and check if your hard drive appears in the Disk Utility window. There's a possibility that the hard drive was damaged by the impact. There's also a possibility that the logic board has a problem since you don't get video on the external. The final question is: do you really want to repair this machine or buy another one ?
I'm beginning to think I just need to buy another one !
I've searched this and found way too many people who had the same problem. Apple should have recalled.
Thanks for you help and I guess I need to go shopping. ( Bah !)
I had the same problem i took the screen apart i have done it before on 3 other machines and have been successful but with this,still a white screen
i got a new screen and cable and it still doesent work it does through an external moniter so i dont know what the problem is just thought mac would have something to help this problem the design is so bad cbles cut by hinges why would you design it like that
i cant see any other way of fixing it even mac repairs said it would be around £300 to fix not including postage and hourly charge whats stupid easier to buy an external moniter and fit it to it
ok i understand you just but a main display then replacing any other in yopc that is gvood for your pc than u. it cost 12000rs/-(indian)
Remember this sites name? It is possible to replace the LVDS cable and hinges. But I agree - not an easy task. I did this a few times and glued the display casing back together using cyanacrylat.
http://www.thebookyard.com stocks all spares needed, sorry but i didn't check iFixit.
The most difficult part of the job is fiddelin' the LVDS through the gap in the bottom case since the cable is really fragile.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 4,823
