Saltar al contenido principal
Versión renovada del iPhone 3G con velocidades de procesamiento más rápidas. La reparación de este dispositivo es similar a la 3G y requiere destornilladores simples y herramientas de palanca. Modelo A1303 / 16 o 32 GB de capacidad / respaldo de plástico negro o blanco.
Preguntas 1502 Ver todo
won't boot shows either battery logo or apple logo
my 3gs won't boot/startup to the home screen
itunes picks it up shows capacity etc etc
After holding down the power + home button, i tired restoring it seemed to work but rebooted then was stuck on apple logo then showed red battery with lighting bolt then shows apple logo again.
It does not seem to be taking or holding charge
I tested what google told me was the battery fuse for continuity and also the two charging fuses and they are not blown.
Tried restarting computer with iphone plugged in, plugging iphone in while holding home button, holding my tounge the right way etc
The phone is completely stripped down at the moment. How can i charge the battery by itself (battery out of phone) can i just cut a usb cord and put the power straight onto the battery terminals?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario
the apple logo come and go
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
This is only the problem. Battery is damaged. you just change the battery . if will sure work properly. donot cut the power cord like this mad things.
see the steps :
iPhone 3GS Battery Replacement
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
i know how to remove the battery, i have the phone completely in pieces the battery is sitting on my desk.
I want to try and direct charge the battery to see if that is the problem and to make sure it is not the dock connector. I have read on google about people thinking their battery was dead only to replace it and their phone still doesn't work
- de
try to get another iphone then put this battery in another iphone and leave it for 2-3 hours to get back to life . if still not get back then have to change the battery is last option
- de
did you guys ever find a solution.. I have this exact same problem. I'm scared to buy a battery in case that's not the issue. I bought an lcd screen bc my old one shattered and my battery was working perfectly fine before I switched screens.
- de
try to restore your phone: plug in the usb to your computer and open itunes. Then press the home key and the "sleep wake key" at the same time for 10 seconds. Then let go the the "sleep wake key" while still pressing on the home key for an additional ten more seconds. A note will pop up on the itune screen asking if you want to reset.
Puntuación 0
Do this
Charge Your Phone or replace the battery
Turn off the phone hold sleep and home
when its off hold the home button and connect it to the computer FIRST the usb in the computer then the phone with holding home
it will boot into recovery
Restore
if jailbreaked use custum firmware
Hope this helps
Puntuación 0
I am having the same issue with an iPhone 5. I can put it into recovery mode, but it fails every time. Did anyone ever find a definitive answer to this?
Puntuación 0
1 comentario:
did you ever find a solution? I'm having the same problem with my iphone 5c
- de
Añadir tu respuesta
bobby777 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 10,914
