Overheating : LED #4 RED is on after 2 minutes
Hi,
LED #4 RED is on after 2 minutes after start a machine.
Computer shutting off after LED 4 on red. Could not possible
to run ASD. CPU heat sink close to cpu very hot but upper
heat sink park cold.
Any ideas ?
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
Hi, Mayer
my board did not have any buttons on the front, only power button on the
back side. I found SMU connector free-no wired connected. And CPU FAN connector connected to the HDD fan and HDD FAN connector to the CPU fan,
so weird. All caps looking great. I will try a new heat sink tonight .
P.S. my board is 820-1766-a
por
Please give us the last three figures of your serial number located on the bottom of your stand. Thanks
por
Unfortunately I dont have a serial from this machine, someone pilled of
sticker from stand. Model #A1145 and this logic bord replaced a year ago.
Thanks
por
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
There are two CUDA buttons on the logic board to the left of the diagnostic lights. Try pressing the lower one (just once), this resets the SMU which manages wattage and thermal conditions. Use the eraser tip of a pencil to do this. Now press the upper button to restart. If it's still hot examine the 24 capacitors on the logic board for swelling and/or corrosion and let us know your findings. Your CPU may have failed but it could also be the caps problem.
Fue útil esta respuesta?
Calificación 3
Comentarios:
OK, different machine. Try pressing the button in your first photo.
por
Añadir tu respuesta
Vitali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 2,074
