Model A1046 or A1095 / 1280x854 screen resolution
Preguntas 162 Ver todo
Why is my PowerBook g4 screen white?
I have a powerpook g4 with a broken screen. I replaced it, but I have a white screen (no display). I plugged in an external screen and it came great.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Solución Elegida
I change video cable also but still white screen
Fue útil esta respuesta?
Calificación 1
Comentarios:
If your machine works as it should on an external monitor then the video problem on the internal monitor should be related to the LCD panel or the LVDS cable.
por
Respuesta Más Útil
Here's a link with great pictures of someone who had the same broken screen problem you have. http://www.david-reitter.com/software/Po...
The first thing to do would be to reseat your cables and review carefully the installation instructions you can find here: PowerBook G4 Aluminum 15" 1.5-1.67 GHz Display Replacement
Are you sure thenew display was good? Where did it come from?
Calificación 4
Comentarios:
thank u. i bought it from laptop aid on ebay
por
looks like some very low prices. Problem s that we don't know if it works
por
Looks like a LVDS (video) cable issue. Double check the connections to the main board and to the LCD panel.
Calificación 3
Añadir tu respuesta
ibrahima estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 4,274
