Saltar al contenido principal
Versión CDMA del iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben reemplazarse como una unidad. Compatibilidad de 16 o 32 GB / Modelo A1349 / CDMA.
Preguntas 295 Ver todo
How to fix a sunk in power button
So, my iPhone4 was perfectly fine until a couple weeks ago. I took it out of my pocket and I discovered that the power button had "sunk" in. It still functions; however, there is no click or resistance when I press it down. I have to push a lot harder in order for it to properly work. I have take then entire phone apart in order to attempt a fix, but I cant figure it out. The power sensor cable seemed perfectly fine (the yellow 'nub' was still intact). Any suggestions on what I can do to restore the original function and regain the clicking?
Any help would be greatly appreciated.
also, theres no water damage nor has the phone been dropped.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Unfortunately that is a common problem on the iphone 4.
The problem is that originally there is a small black 'dot of plastic' on top of the switch (on the flex) which activates the switch when you press.
Most likely this black dot has disappeared from your switch. The best way to solve this is to replace the power and sensor flex assembly:
[producto vinculado inexistente o deshabilitado: IF189-004]
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Christian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 23,326
