Saltar al contenido principal
Guías de reparación y soporte para automóviles y camiones por Mazda Motor Corporation.
Preguntas 282 Ver todo
Fix the driver's side door interior panel in Mazda Tribute SUV?
The interior driver side door latch no longer works. I suspect the linkage inside the door has broken or come apart. I need to know how to disassemble the door panel to gain access to the door latch mechanism.
Es esta una buena pregunta?
Puntuación 2
1 comentario
Tom, what year is your tribute?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Tom, you forgot to tell us the year of your vehicle. This should work for you "1. Remove the door sail panel. If equipped, disconnect the power mirror electrical connector. LH side shown, RH side similar. 2. Open and remove the door handle finish panel. Pull the door handle outward to fully access the door handle finish panel. 3. 4. 5. 6. Remove the door handle screw. Remove the door inside handle screw. Remove the 3 door trim panel screws. Remove the door trim panel. Pull outward and then upward on the door trim panel. Disconnect the electrical connectors. 7. Remove the door handle from the door trim panel. Disconnect the electrical connector. Press the 2 retaining tabs while pushing the door handle from the door trim panel. Remove the door handle from the door trim panel by pulling it back through the door trim panel. 8. To install, reverse the removal procedure." from [http://Mitchell Repair Information Company,|here]
Fue útil esta respuesta?
Puntuación 3
I have a 2004 Mazda Tribute drivers door will not close it won't latch when you shut the door how do you fix this.
Puntuación 0
3 comentarios:
i have the same issue 2001 tribute. I slammed the door close it is shut but now exterior handle is loose and not working, while interior is also not working and the lock button seems jammed
- de
Some issue with the passenger door. Anyone have the schematic for that door?
- de
@rottjocky what make and model vehicle are you inquiring about? What is going on with your door?
- de
Añadir tu respuesta
Tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 34
Todo El Tiempo: 8,019
