How to put belt on the mower deck
how dose the belt go on the mower deck
Es esta una buena pregunta?
Mike,
Usually there are two belts. One goes around two pulleys, a front pulley under the motor and one on the mower deck. Additionally, there is usually a spring tensioner pulley that rides against the belt to allow it to work and for ease of routing.
The second belt goes under the first belt and is routed on a common pulley with the drive belt and both (or all three) of the mower blade pulleys.
Here is a crazy looking exploded view of a craftsman mower deck
And here is a better diagram of it all put together. I think you can get an idea of belt routing out of this one:
Fue útil esta respuesta?
Do I have to bend the metal bracket that keeps belt from slipping off pulley to put a new belt on. The belt will not go on pulley unless I do bend it back.
The bracket that holds the blade belt on the pulley is stable and will not move. How do I get the belt on pulley without bending it
Ultimas 24 horas: 24
Ultimos 7 días: 193
Ultimos 30 días: 683
Todo El Tiempo: 61,630
6 comentarios
how to put blade belt on modile 917289031.
- de cynthia
What about 3 belt craftsman.I have 2 ride mowers one is 2 belt other is 3belt ?? The deck belt patterns are different
- de Vincesnowgren
is this for a deck on a 7000 series 42" cut mower?
- de gary
This is. For the 2ooo series. Model 247.288852. Serial # 1A192B10186
- de Vincesnowgren
46 inch deck
- de Vincesnowgren
Mostrar 1 comentario más
