How does this tiny piece fit back into the control switch?
Not knowing the play/pause/volume control was part of the earphone wiring and therefore not noticing that it was stuck to the packaging tape, the control's casing came apart when I took the tape off the packaging. A tiny strip of metal fell out and it seems to control the volume. (I was able to easily snap the 2 halves of the casing back together and the center button that forwards, etc still works)The very thin strip of metal is a little less in length than the inside of the control and about half the width, with one piece of metal about 1/16" square on each long side bent at a 90% angle. I suspect it fits inside the control switch somehow. Can I fix it myself? Is there a picture available of the inside of this switch?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Karen: If it broke when you took it out of the packaging from Apple, Call Apple and have them replace it under your warranty. Their number is 1-800-275-2273
Fue útil esta respuesta?
Calificación 3
Comentarios:
great answer +
por
Añadir tu respuesta
Karen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 2,690
