Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2397 Ver todo
Poor Service/Wifi after changing digitizer
So I replaced the digitizer on my phone and ever since the wifi signal has been absolutely poor. Does anybody know what may cause this or if I might of messed up a part doing it.
Es esta una buena pregunta?
Puntuación 1
1 comentario
What if that little part on the backside of the cover is missing. Can you buy a new, or do something Else, to fix it?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
You have done one of two things wrong. Either you have had this tiny part fall off and you did not know where to put it.
It goes here
Or you did not use the correct length screw in this hole. The longest screw within the iPhone goes here.
Also the oil from your fingers can affect Wi-Fi signal strength. So clean all contact points with Isopropyl alcohol.
Revision
To show you which screw is in fact correct I have edited an image of the whole set of screws within an iPhone 4.
Complete original set of screws.
Shown here is the screw that I originally said was the correct screw. In fact I was wrong.
Here is the actual screw required. Please note that it has a smaller head diameter.
Fue útil esta respuesta?
Puntuación 5
2 comentarios:
great answer with pics too?? absolutely a "+"!
- de
Thanks for the help man!
- de
Where does that squiggley black piece go?
Puntuación 0
It goes on top, above the battery, near the camera:
Puntuación 0
Añadir tu respuesta
Arron Mayers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,264
