Saltar al contenido principal
Modelo A1311 / Finales de 2009 / Procesador Core 2 Duo de 3,06 o 3,33 GHz
Preguntas 310 Ver todo
Seagate HD S.M.A.R.T. Status failing
Suddenly, I have an error in Disk Utility for my Seagate ST3500418ASQ hard internal disk, like this :
S.M.A.R.T> status failing (red coloured)
After this moment, I can`t do anything with disk. What is this and how to solve this problem ?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The SMART error is an automated diagnostic error that detects impending failures in a hard drive. This is indicating your HD is about to fail and needs to be replaced. I believe this is the correct iFixit hard drive replacement guide for your computer. If not, the designs haven't changed much (internally, at least.)
As for data recovery, you can try placing the "bad" HD in an external USB enclosure and seeing if your recovered mac, or another mac, will be able to read it. If not, you may need to seek out a professional data recovery service. Seagate does offer data recovery services.
Let me know if you have any follow-up questions.
Good luck.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Sasa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 3,837
