Saltar al contenido principal
Todo lo que puedas necesitar para reparar tu iPhone tú mismo Desde la línea más reciente de iPhone 15, hasta el iPhone 2G original lanzado en 2007, iFixit tiene guías de reparación gratuitas e información de desmontaje para cada iPhone, así como las mejores piezas de repuesto, herramientas y consejos de la galaxia.
Preguntas 36446 Ver todo
When I click on app store it's frozen
I tried to download twitter from my app store. When i confirmed the download the "download now" button popped up, but now it's frozen on there. I can't push the ok button or anything else. I can hit the home button and do everything else, but once I try to go back into the app store, it says the same thing and is still frozen.
Es esta una buena pregunta?
Puntuación 26
2 comentarios
You guys are awesome. Thank you. I double tapped the home button and did the red dot trick. Thank you again.
- de
Happy to help :)
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Reboot the Phone - Press and hold the home and power buttons till the iPhone resets and restarts or simply power it down.
Another trick I have used (supposedly) to reset mail is to double press the home button - may work on other apps??
The screen will dim all the icons and you'll have a row of icons only across the bottom of the screen. Slide the icons left/right till you get the App store icon
Press and hold the icon till a little RED DOT appears on it
Press the RED DOT
Just found this LINK
HIH
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I need help to it does t
He same thing to but mine just frozze when I put in games and what do I do
- de
With crashing apps i find the best way to help it is do "force quit"
Hold the sleep/wake button for 10 seconds
Let go
Then hold the home button until you return to the home page.
1.This helps with thing like ; apps crashing (especially immediately after purchase)
2.Home button not responding
Also remember to quit running applications by double tapping the home button until the multitasking bar appears. Hold your finger on any of the apps in the bar until they shake and tap the stop sign circle in the left corner of the open app (As above)
Puntuación 0
Thank you it worked all sorted . Wish I’d found you earlier.
Puntuación 0
Añadir tu respuesta
Thomas Mahony estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 39,379
