water full light not going off
the red water full light stays on and i can not get it to go off. it sits there with the water full light on and will not actually come back on.
Es esta una buena pregunta?
Is there an internal water tank? If so, check that it is correctly positioned inside the cabinet. Even if you have a constant drain setup, there will be a sensor or switch to confirm the tank is installed correctly. Perhaps this sensor/switch is damaged or jammed.
Also the compressor may have a time delay after the tank is installed - wait a while to see if it starts up OK
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,199
1 comentario
I can't find the owners manual to this online, oldturkey03 may have one. If you have your owners manual look in it to see how the trigger for the water level switch sits in the bucket. Usually this happens when the bucket is drained and the trigger is not returned to the proper position.
- de ABCellars
