Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac Mini Server configuration.
Preguntas 184 Ver todo
Broken ir connector(?), possibly to run without?
Hi,
I have successfully managed to detach the what i think is the ir connector from the logicboard. And therefore I can not connect the wire with 5pins onto the logicboard.
Can anyone please confirm that the cable is intended for the InfraRed function on the Mac mini server 2011?
And please say that I can use my mac mini server without that cable!? Or must I send it to service?
Thanks in advance!
Fredrik
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
It is hard to give you an answer without pictures of what is broke off and where it is located on the board. You have the ability to trace where the wires that connected to the header lead. If you are not sure what they go to, we can't be either.
por
Agregar un comentario
1 Respuesta
Solución Elegida
If you can do without sleep and some other functions - they are, I believe, included on that sensor.
Remember to return and mark accepted the answer that best solves your problem.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Was wondering if anyone had pin assignment info for the IR header, and sensor info. Thanks in advance!
por
Añadir tu respuesta
Fredriknoren estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 9
Todo El Tiempo: 1,272
