Saltar al contenido principal
Hay tantas cosas que podríamos hacer si supieramos cómo. Esta sección apunta a catalogar las habilidades más especializadas necesarias para realizar cierto tipo de reparaciones.
Preguntas 488 Ver todo
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
- de
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks for the advice oldturkey03 :D
Here's that: Técnica del Kit de Destornillador iFixit de 26 puntas para quitar puntas
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
- de
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Puntuación 0
Añadir tu respuesta
aaronmiller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 1,160
