Model A1199 / 2, 4, or 8 GB capacity
Preguntas 95 Ver todo
Why is there a "do not disconnect" logo on my screen
We just bought a used iPod and there is no booklet with it. When I plugged it in to my computer via a USB connector there is now a sign blinking and saying "do not disconnect". Is there a problem???
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
i am using 7th ipod nano and it says okay to disconet but it just stays there i tried reseting it and puting it on disk mode not of this worked
por
Agregar un comentario
4 Respuestas
Solución Elegida
it has a do not disconnect on it because your iPod is trying to talk to the computer. If you disconnect it without first removing it from the computers desktop you can corrupt both the iPod and the computer.
Go to : http://support.apple.com/manuals/#iPod and locate your iPod and download the manual.
Take care
Fue útil esta respuesta?
Calificación 4
Respuesta Más Útil
This is normal. There is not a problem. You simply have to go into your iTunes program and 'eject' the iPod. The eject icon is a triangle over a bar just to the right of where it lists your iPod on the left column in iTunes.
Roll your cursor over the triangle and press once. After just a couple of seconds, your iPod will be ready to disconnect and the "do not disconnect" logo will disappear.
Good luck,
Frank
Calificación 9
@debbie
Make sure you use iTunes, and connect your iPod.
Select your iPod in the navigation panel on the left, Devices section.
Now use the Music button in the top menu.
Select to synchronize only "Selected playlists".
Only the tracks used in the selected playlists will be synced to your iPod.
The other tracks in your music library will not appear on your device.
Calificación 3
toggle hold switch 5 times, then hold center button and menu button at same time for 10-20 seconds. Sounds crazy, but it worked for me!
Calificación 2
Comentarios:
Thank you for sharing this! It worked for me too! I didn't want to have to recover and reset it.
por
but this happens every time i connect it
por
Añadir tu respuesta
Lee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 18
Últimos 7 Días: 97
Últimos 30 Días: 437
Todo El Tiempo: 13,928
