Saltar al contenido principal
How to troubleshoot a gray screen on start up.
I have a Apple A1010 laptop that when you turn it on, it chimes and goes to grey screen and doesn't do anything. It is not the hard drive or the memory because I tested them in another laptop.
Es esta una buena pregunta?
Puntuación 2
3 comentarios
I did that but the ram is good this laptop has 128MB of built in RAM thats not removable. could that be the problem
- de
When you tested your hard drive in another computer, were you able to boot off of it? If so, you might want to make sure everything is connected properly inside you laptop.
- de
yes it booted up fine and the conections are tight.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I guess you tried all usual troubleshooting stuff like reset the pram, reset the PMU, boot from external source, boot in single user mode, fsck scan, connect the PB to an external monitor, etc ?
Fue útil esta respuesta?
Puntuación 2
Test the RAM in another laptop, could just be bad RAM.
Puntuación 0
Añadir tu respuesta
Mark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 2,478
