Saltar al contenido principal
Todo lo que puedas necesitar para reparar tu iPhone tú mismo Desde la línea más reciente de iPhone 15, hasta el iPhone 2G original lanzado en 2007, iFixit tiene guías de reparación gratuitas e información de desmontaje para cada iPhone, así como las mejores piezas de repuesto, herramientas y consejos de la galaxia.
Preguntas 36462 Ver todo
How can I charge a battery without the iPhone
Hello can anyone suggest how to charge an Iphone battery without putting it in the phone ? I need to charge quite a few at a time so I don't want to keep putting them in the phone. What would be my best option and what type of charger would I need and max voltage etc...
Thanks in advance
Steve
Es esta una buena pregunta?
Puntuación 5
2 comentarios
i changed battery to find out phone wasn't charging,so fitted new charging port.
still did'nt charge.
then new battery drained.
so could'nt factory reset.
so came up with an idea,i knew there wasn't nothing wrong with the original battery so i stripped the end down where the contacts are and soldered 2 wires to batteries positive and negative points and wired other end to my intelligent charger.
battery is charging now,hopefully when fully charged i can fit back in phone and hopefully do a factory reset.
i will let you know if i get it fixed.
- de
Is it possible to fix the actual port?? As that seems to be the issue I am having. Bought a new battery too only to find out the charging port is the problem
- de
Agregar un comentario
4 Respuestas
Solución Elegida
I'd use a prototype breadboard and use a diagram like the one attached. Solder the resistors and the USB cable to the breadboard on one end and attache something like alligator clip wires to the opposite end. That way you can use it for all different batteries. Any iPod/iPhone charger AC charger in theory would work, all you have to do is find the pinout i.e. pinout.ru and tap it from a USB cord. Then connect your battery via alligator clips to the circuit.
UPDATE
This would be a circuit to use from a 12volt charger. There are so many variations out there give it a try and see what will work for you. Of course make sure that you have a multimeter and measure your circuit before you try to charge your battery. there is great infromation on here and here. Hope this clarifies it a bit....:-)
Fue útil esta respuesta?
Puntuación 7
7 comentarios:
Thanks oldturkey, again ! good job you don't charge or I would be broke by now :-) Your a real gem. I will post the image when I have made it.
- de
Sounds good....let us know.
- de
Where do I get the image of your circuit. I do not see it in the post.
Thanks,
Jason
- de
Jason, it got deleted because I was over my limit of posting images. I will see if I kept a copy of my Hard drive. Email me and I will see if I can send it to you, if I find it.
- de
Okay so check on here http://circuitpowersupply.blogspot.com/2... and subsidize the S1 = USB 'A' Type Socket for a pair of banana clip wires that you can hook up to your battery.
- de
Mostrar 2 comentarios más
Please refer to the following site:
http://yundorri.blog.me/220203447319
Even if above page was written in Korean, images in the site could be useful.
Puntuación 7
5 comentarios:
Hey, yundorri, although i didnt understand a single word of your site, it were VERY HELPFUL. Through the images i could charge my iphone 5 battery directly.
Thank you very much!
- de
Your welcome!
May be the joyful phone-ing :D
- de
Sounds very useful. I will try and let u know if it eacan help to charrge my bat tery
- de
Good Luck!!
You don't need to charge your battery fully. Just charge 3~5 minites. It will be charged enough to loading the charge software of your phone.
- de
Just so its known, that korean sites pics do help, but it helps to know he was reviving an old battery so he could charge it, not wiring it up to charge. Just work around that i guess, says u need 5.5 whr or whatever (new to apple works, they suck, cant just be amps?) And 5v, to 9v, or something like that. And apple, if u read this, cuz im sure youll eventually have this removed, you suck, stop being reverse pirate vampires
- de
i changed battery to find out phone wasn't charging,so fitted new charging port. still did'nt charge. then new battery drained. so could'nt factory reset. so came up with an idea,i knew there wasn't nothing wrong with the original battery so i stripped the end down where the contacts are and soldered 2 wires to batteries positive and negative points and wired other end to my intelligent charger. battery is charging now,hopefully when fully charged i can fit back in phone and hopefully do a factory reset. i will let you know if i get it fixed.
Puntuación 3
1 comentario:
How are you going to reconnect the battery to the iphone?
- de
solder wires to the bms board and charge it thru cable
Puntuación 0
Añadir tu respuesta
Steve estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 38,013
