Replace the fuel filter.
How do you change the fuel filter on a 2001 Dodge Grand Caravan?
Es esta una buena pregunta?
Not a common thing to change. It is underneath the van on the passenger side top of the fuel tank (which is on the driver's side of the van). The fuel tank must be dropped to access the fuel filter assembly. In order to do that remove the front strap since the fuel line goes behind it. Loosen the rear strap so that the tank drops and will clear the line. You should now see the filter assembly. Check also with your local Chrysler dealer. The 2001 Caravan had a recall issued for some aftermarket replacement fuel filters that could cause the fuel lines to leak and result in a possible fire. I would have them check it and see if there is any sign of damage to the fuel filter or if it leaks. leakage in the fuel lines, the filter should be replaced. Check on here for the recall. Good Luck with this task.
Fue útil esta respuesta?
I'm having a problem changing one on a 2001 grand caravan. The problem is the Ryan or return line doesn't fit the port on the pump. The grommets keep getting stuck. Both of the other connections fit just fine.
Was not trying to say Ryan.
Just got it together. Food for thought, if it's below 40 degrees and your outside the plastic is very stiff. Take the filter inside and let it warm up good. That with a little vasaline on the return port of the pump and it slid together. And praise God for a mother who prays for me while I work on her van.
Not 40 below but below 40 in southeast Missouri. Was definitely cold enough to make all the plastic too stiff to slide together.
Spread this around. The fuel filter in the2006 grand caravan is a sock inside!, the fuel tank. A lot of people are asking about this. I know first hand because I have one..
Well I was told by a guy at Auto zone that the fuel filter on a 05 caravan is part of the pump so you have to replace the whole thing
Very true for an 05 model. Not so for an 01. Starting on the 04/05 models the external fuel filter was eliminated. They now just have a small sock filter on the pickup tube on the fuel pump inside the tank.
If I had to put a fuel pump in it to get the filter changed I cut me a whole line in half and install me one long the frame
You need a ¼ “ vinyl clear hose with a cut 30 degrees to go through the filling house in the tank to evacuate gas from the tank. You need a fuel tank jack to lower and reinstall the fuel tank. You can make a wooden fuel tank cradle for less than 10 dollars, and installing it at 1” hole under the jack cup.
The fuel FILTER on a 2007 Caravan is built into the Fitting that comes out of the TOP of the Fuel Pump ASSEMBLY. It is NOT removable. You MUST change the whole ASSEMBLY. This CLOGS and causes the Overload clipped to the top of the pump to blow. The pump is actually still good, but I know of no way to get a new OVERLOAD to clip to it. If you change only the pump on the fuel pump ASSEMBLY, no fuel will flow out the Top of the Assembly because the Internal Filter is Clogged. Buy the whole ASSEMBLY and save yourself some aggravation….
Ok I'm a female with no experience .ok lol and I tried to go to store this morning. But it started but won't stay started. So I'm thinking fuel filter must be clogged. Right or wrong ?
Ultimas 24 horas: 2
Ultimos 7 días: 43
Ultimos 30 días: 179
Todo El Tiempo: 62,517
2 comentarios
wher is the fuel filter located on a Dodge Caravan 2003?
- de Ronald Holcombe
I have a 2007 dodge grand carivan. Where is the. Fuel filter located?? What is under driverseat on the frame? Please help
- de tammyquick155
