iBook G4 has bad airport card. How do I disable airport
I get a kernel panic when iBook boots up. I think it's a bad Airport Card. How can I disable airport in safe mode?
Es esta una buena pregunta?
Open your system preferences, go to Network and turn it off.
Fue útil esta respuesta?
Thanks Mayer, but I get the kernel panic on boot up, so the only way for me to access the iBook is in safe mode. Airport is disabled there and grayed out in Network pref's. I know there must be a terminal command to disable it. I'm thinking I can just disable the airport card and buy an wireless USB adaptor...
I am in Tiger
The Terminal command would be: sudo ifconfig en1 inet down
Out of curiosity, reboot the iBook while holding down SHIFT to get into safe mode.
Does it still kernel panic?
Restart OS X normally. Does it still kernel panic?
If so, have you considered physically removing the Airport card?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 488
