Saltar al contenido principal
Esta Nintendo DS Lite se lanzó en 2006 como sucesora de la Nintendo DS. Entrar dentro de este dispositivo es simple, lo que facilita las soluciones.
Preguntas 316 Ver todo
DS lite turns off when digitizer is touched?
I have a DS lite that I replaced the upper LCD on. It turned on fine once i had the shell back together, and the start up screen loaded, but when i touch the bottom screen at any point the whole unit shuts down. If i dont touch the digitizer it will remain on and power on/off normally. The only problem occurs when you touch the digitizer.
I was kind of at a loss as to what to do so i checked/cleaned ribbon cables, replaced the Fuses and even the L2 inductor, but still have the same problem. I have all the parts and tools required to do repairs, but I'm new to DS's and cant find anything on this.
Anyone have any recomendations?
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
I believe it has something to do with the metal on the back of the LCD making contact with the components underneath (so not the touchscreen as such) there is a black plastic liner around the screen that prevents this from happening. Just check it is still in place.
see this answer
Fue útil esta respuesta?
Puntuación 7
7 comentarios:
Thank you, Ive gotten held up by some other repairs/life, but will try your suggestion tomorrow and let you know if I had success. I looked in the case the new shell came in, and there's definitely a black piece of backing that looks like its supposed to go on the back of the touchscreen.
Thanks
- de
by the way, this website is AWESOME!
- de
Thank you, a single layer of electrical tape did the trick.
- de
john, if that answer helped you out, all you have left to do is to ACCEPT pollytintop's answer as the solution...:-)
- de
Lol, answer gratefully accepted. Seems I'm still learning all sorts of new things :)
- de
Mostrar 2 comentarios más
Añadir tu respuesta
John estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 2,514
