The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic.
Preguntas 27 Ver todo
How to Repair Nokia 5130 XpressMusic`s Music Player?
When I open the Music Player a message pops out and says not enough memory.
How can this be fixed? Pls. anyone?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
LMGTFY, It appears as if you need to flash your phone. Here is a site that will help you with backup files if you do not have a recent one. Check all the links. link 1 and here is link 2
por
Agregar un comentario
6 Respuestas
Solución Elegida
this is the software problem. this will not solve even after reset . you have to flash it means upgrade or install same version on it. this will solve this issue. if you have a dongles (Mx-key, Zaf, Ufs, Infinty, ATF(Advanced turbo flasher) any one from this . download the same Rm-495 latest version from support site then flash it . if you are normal user then you can use the Nokia software updater (download from Nokia site free software) then connect the file it will atumactically download the latest version and it will flash it . then you are ready . thumbs up. note that battery must be fully charged .
Fue útil esta respuesta?
Calificación 4
Comentarios:
+1 good answer.....
por
Bro This is a Software Problem Flash With This Version Nokia 5130 rm-495 v7.91
por
Mehak Mahoo, it is a good answer, but it is the same answer as the one from SIMRAN, except 4 month later. For that reason I moved it to his answer.
por
flash ic
por
what if there no update available for this device sofware or application updates
por
how to update
Calificación 1
bhai jan nokia 5130 main player ka masla hy to kia kro jaldi btao plz
Calificación 0
Comentarios:
bhaiiiiiii jaldi flash karlo ehnu nai holi holi eh vi band hoju...
por
What can i do
Calificación 0
My music player and fm radio are not working; when I try to open any media file the screen goes blank and a pop-up says "not enough memory", however, when I use the music keys, media works though without displaying either the music player or fm radio.
I'm not using any of the phone memory, and have more than 400 MB free memory on the memory card.
What should I do?
Calificación 0
are yar flash process chal rahi thi tabhi mene galti se disconnect kar diya tabhi se mera phone chalu hi nahi ho raha (flash mode me bhi nahi jata)
or aise ERROR aa rahi he,(please help)
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 308032 bytes
Update server loaded
Error initializing Algorithm. 0x8400A814
ERROR: Failed to set phone to flashmode
Starting to recover the phone
Recovering phone
Initializing
All operations completed
me kya karu?
PLEASE HELP
Calificación 0
Añadir tu respuesta
franjoshval123 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 18
Últimos 30 Días: 82
Todo El Tiempo: 42,261
