Smaller, thinner, quieter model of the Playstation 2 (SCPH-7XXXX) released by Sony in September, 2004.
Preguntas 37 Ver todo
Optical drive not spinning up
The CD does not spin. The laser unit and the spinner are brand new. What do I need to replace? I bought the entire disk unit that includes the motor of the spinner the laser lens and the cables included.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
hi I have a ps2 slim I still like to use for guitar hero but it wont spin or read and lazor does nothing everything is connected but the ribbion on the optical lazor lens was torn so I took one from a dvd player same with cud that b the problem it comes on jus fine and I check all the switches and still wont spin or read please respond asap so I know what I gotta order to fix it
por
hi i have a problem with my ps2. my ps2 is really old 8 years. at first 1-3 yrs ago it works fine but a little difficult to turn the game on because if fail sometimes and 4-7 yrs ago it's now really difficult to turn the game on i kept restarting it like the game plays at 15%. And now in 8 yrs it now didn't work to turn on the ps2 so i got a major problem, I know my PS2 is very old but is there any idea what to replace it with? My email is rapha_raphael54@yahoo.com so please send me a message thanks you.
por
hi bro my ps2 model is SCPH 90001 and my dad bought it around 2008 maybe and i havent touch it since back then , and now ive decided to use it to play and it appears on screen " the red screen" which says insert playstation format disc .. jow can i resolve that, my neighbor says that my ps2 needs to be modified... i dont know what to do bro pls help.. hoping for your answer btw my ps2 is slim
por
Hi my PlayStation 2 is not showing on my T.V wat should I do
por
Agregar un comentario
11 Respuestas
Solución Elegida
The PSTwo has two door sensors. Nothing will spin if it thinks the door is open. The first and least likely to fail is a little black nub right above the power switch. It must be pushed down. The second is way at the back, to the back left of the laser assembly, and is a white or brown plastic box with a tiny plastic nub sticking up. It needs to be down as well.
Easiest way to test is to remove the lid altogether, and manually press down both sensors, because you can access them both easily. Have a disc in, turn it on, and press down both sensors. If it works, disable one or both of the sensors, and you should be playing in no time.
Fue útil esta respuesta?
Calificación 4
Comentarios:
did this and the disk don't spin but laser moves
por
Thats great. yes you were rt about pushing down the NUBs,..so i disabled them and Wala NOTHING WORKS ONCE AGAIN AND now i have no NUBS TO PUSH BECAUSE I REMOVED THEM...NOW WHAT....BE WARY OF THE WORD DISABLE...FOLKS otherwise then that you did excellant on youre fixit ,its more ME at fault to make the word DISABLE and REMOVE as the same action...because it is by far not.
por
Where is the nubs? I can't find either one.
por
if you remove the nubs you have to strap the tracks its a switch
por
Respuesta Más Útil
I know this is old but I wanted to give more of a complete answer.
1st check if the laser moves when the lid closes or first powered on. If it don't move then most likely it is the two switches that detect when the lid is closed. The one in the back side of the system near the middle is common to have issues, soldering a wire from one side to the other will work well and I have done it several times.
2nd we should beable to rule out the switches so now the question is, has the system been worked on before. If it has, the ribbon cable for the motor that spins the disk is common to get messed up where it plugs in.
3rd If everything appears to be working correctly but the disk won't spin, try a CD in it. It is very common that the cause is that the system don't "see" a disk in the drive and most common media is DVD so that is what wears out. If it reads the CD fine, then most likely it is the laser.
4th Just to note as above, there is a small break for the disks and if that is not released when the lid is shut, it will have problems reading the disk, but it WILL spin still.
5th Once I had a "worm" motor go bad that moves the laser. The case I had it would see the disk but would not read it. Found the laser didn't move at all. When the system is turned on or the lid is shut, the laser should always move to the center of the disk and a small switch is pressed so the system knows where the laser is at. Also the switch can go bad and continually try to move to laser to the center causing a clicking notice that don't go away until you shut it off.
Hopefully this can help answer some questions for the readers of this question and point them in the correct direction.
Source: Fixed and modded PS2s for over 5 years
Calificación 7
Comentarios:
number 2 is the problem for me i think. what should i order to fix it?
por
where about it the switch that is in number5 when the laser moves to the middle it keeps going
por
Hey so number 5 is my problem, but i just barely bought a new laser with a new switch. I heard somewhere that it could be the bars bent but i dont think that is the problem because i checked and they seem straight. Could you email me your comment? at hugmuffin26@gmail.com
por
my problem seems to be number 1. What do you mean by soldering a wire? From where to where?
por
I think that all mine is the nubs but mine still isn't spinning even doing what you said what should I do now?
por
Mostrar 4 comentarios más
There is a mechanical break for the DVD disc. It is released when the cover is lowered. 4 weeks ago my friends came to me with same "disc not spinning issue" and i found that the small plastic lever molded on the cover at the right back side is broken and thus not allowing the break to be released. The spindle motor is gentle so it has no power enough to spin the disc with the break on. I simple removed the break. It helps for disc to stop quicker when cover is open accidentally and its not big deal if u remove the brake. Just wait 5 more seconds before you take the disc off.
Calificación 2
Comentarios:
Hey, my problem is I was trying to fix the laser with no research beforehand and I took the shield on top of the lens off, and ended up taking out the small square lens piece and I think a ribbon that was attached somehow broke off, any way I could tweak it? Plz !&&* I can't find anything online related to my issue
por
The lens may have an anti static solder ball that needs to be removed.
Calificación 2
Comentarios:
This is a simple yet relevant information if you have substituted the lens for a new one.
por
Where would that be located? Also what would it look like?
por
If you just bought it then it should be under some sort of manufacturer's warranty, so I suggest you get it replaced before you start voiding the warranty.
Calificación 1
check to see that everything is plugged in properly and if that doesn't work you may have gotten a bad part
Calificación 0
I have a question. My disc will spin but it says disc reading for like 5 seconds and then says disc cant be read. I have a feeling its a different problem then the nubs since its trying to read it. Weird thing though if i play with the laser a little bit and move it all the way back, forward or put it in the middle sometimes it'll work but then ill shut it off and turn it back on and nothing.????? Help????
Calificación 0
Comentarios:
Hi Kyle. Have you checked if the mechanism is moving smoothly? The gears that moves the laser back and forth normally gets a lot of dust - I had this issue here once. A good cleaning should do the trick!
por
I found a little nub on the laser that i think tells the worm gear to stop so the laser doesnt hit the spindle. Well this switch is acting like a kill switch for the entire ps2.
Calificación 0
Comentarios:
have you found a fix for it???
por
I really need to fix it! my mom just got a me a controller, and my PS2 is borrowed from a friend who is gonna want it back....
por
same here, lens, its cable and brand new motor but the disk still won't spin. the laser moves and I see the red light of the laser. what could be the issue with this %#*@ things.
Calificación 0
Comentarios:
Same here.... The lens is new (antistatic ball removed), it moves to the center and I can see the laser for ~1s. Worm motor is OK of course but the &&^&^$^ disk wont spin... Everything is plugged right.
por
Motor won't ever budge one inch....
por
I haven't played mine in a little bit (around two years or less) help!
por
My PS2 can only spin when there is a CD, but doesn't read it. The only thing it doesn't spin is any game discs. Not sure why, is it the laser or something?
Calificación 0
Hi :) Ive had a problem for about a year for a certain disc now, when i insert the disc, it reads it, and it would go as far as the "Playstation 2" screen, but after a few seconds after the ps2 screen fades away, the "Please insert a Playstation or Playstation 2 Disc" with the reddish background appears. What could be the problem?
Calificación 0
Añadir tu respuesta
delarosatrevino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 93
Últimos 7 Días: 524
Últimos 30 Días: 2,130
Todo El Tiempo: 129,931
